uiq emulator problem
7 replies · 3,145 views · Started 30 April 2003
Hello, i ve some problems when i want launch uiq emulator.
it doesn't find any class, but my .jar is in the classpath.
my jar is in <dir-symbian>\epoc32\java (virtual drive j ).
my class Hello isn't in a package, the command i type in is following :
pjava_g -cd j:\example -cp j:\Hello.jar Hello
and i ve a java.lang.ClassNotFoundException
thanks for rescue me 😉
vandoor
i ve resolved my problem, i ve install jdk 1.1.1.8 and i ve put my class in a package...
I'm pulling my hair out here!
No matter what I try I always get a NoClassDefFound error!
I am using the j2sdk1.4.0_02, does this make any difference???
It compiles fine and makes the package fine too.
Also, how do you default the emulator to be a P800?
OK, I'm now in a bigger mess!
I can run the example apps in java but not with the emulator.
When I run pjava i get the following message...
Unable to initialize threads cannot find class java/lang/Thread
I am running the j2sdk1.4.1_02 and runtime of the same version.
Anyone got any clues???
for the java/lang/thread problem
you should initialyze an environement variable
_epoc_drive_j = <symbian dir>\epoc32\java
and the emulator will start !!
for problem java.lang.NoClassDefFounfError
you can put the jar file in the directory
<symbian dir>/epoc32/java/ext
the jar will be automatically in the emulator classpath.
so, if the error persists you can put your class in a package.
there are two way that i found toi resolve the problem
ps : sorry for my english 😉
vandoor
if ur using jdk1.4.2 just compile the application in jdk1.1 class format
e.g. javac -target 1.1 -cp......... myapp.java
it will work
e'joy 😊
Prasad
