Help needed accessing P800
8 replies · 1,976 views · Started 30 April 2003
Hi there - could i just say what a useful resource this place has been for a P800 newbie and also apologise if this has been asked before but i did search and nothing showed up.
I have been using a P800 for a couple of weeks now but am having a couple of problems - although this could be with my laptop and not the phone!!
When i connect the phone (USB) everything syncs fine but the phone does not appear as a device in Windows Explorer - it has done once and i was able to rename all my pictures but since then nothing, and i cannot 'explore' the phone.
If anyone could help i would appreciate it. (Oh and the laptop is running WinXP with SP1)
Thanks 😃
Have you tried restarting the laptop?
I had this with a laptop running W2K Server, and found after rebooting everything came back fine.
What version of PC suite are you running? I've installed 1.4.2, without installing any other versions and it works a treat with XP.
Thanks for the help folks - the last post propted me to update to the latest version of PC Suite - and this seems to have fixed the problem, thanks.
Now all i need to do is get the bluetooth sorted and 128MB Duo and i really will never get any work done.
Thanks all :fadein:
Glad to help another P800 owner.....
They say on SE's web site 1.4.2 is intended as an upgrade, but I just installed it as new and haven't had any probs yet - it actually works quite well!
[quote="kingrob"]They say on SE's web site 1.4.2 is intended as an upgrade, but I just installed it as new and haven't had any probs yet - it actually works quite well![/quote]I installed it as new and it worked just fine too.
Fyi... my general rule of thumb is ignore anything that SE's support people say, your life will be easier. :agrue:
Dude this is soo cool, all those unexplained questions, now answerable, with mathematical proofs, my lecturer is gonna love this. Thanks
