im having trouble importing my contacts from 76 to 36, it just hangs at 50 percent, any alternatives?
importing contacts from 7650 to 3650
what program are you using?
pc suite for 3650
How about Bluetooth them one at a time between phones or you could select them all and e-mail them to your 3650
Best
Will
[quote="paloyme"]im having trouble importing my contacts from 76 to 36, it just hangs at 50 percent, any alternatives?[/quote]
If your PC Suite will not do it for you after many tries, install SmartvCard into 7650 & 3650 - Export as .vcf file in 7650 then Import in 3650 using SmartvCard of Symbianware.com but no thumbnails.
Or use the flight mode of System Tools by PsiLOC to enable you to send the contacts.cdb from your 7650 to PC then transfer from PC to 3650.
