which one has better built quality??
8 replies · 2,278 views · Started 30 April 2003
hey im going to get a 3650 tommrow hopefully :P
there are 2 which i saw one which is the chiness flashed verson (not sure)or maybe korea
and the other which says made in Finland
which one has the best build quality??
and do all of these have the Realone player in them??
and i want to know one other thing
can i install video mms on the MMC and then send a mp4 to my phone and play it fullscreen??
Both the same. Nokia doesn't produce different quality 3650s from
different factories despite what people think about Chinese/Finnnish
build quality. Firmware is obviously different though (languages !).
Yes.
Regards.
videoMMS can't load from MMC... but i think there is some way you can make realplayer play videos fullscreen, but it seems to be a little complicated. I wish someone would make an app like video MMS, that could load from MMC, or that there would come some new version of videoMMS that was meant for 3650.
Buy the Finland one! My friend got the flashed chinese thing, and he can't save a picture if it comes by a message, (another guy has it and he doesn't have that problem or anything like it) well just stick to the finnish (IMO) cause the first person later on ended up buying a made in finland one cause his flashed phone started being really buggy.
yep thanks guys I'll get the finland one 😉
yea why cant anyone make a porgram like videomms for the 3650,somepeople here on the forum have complains that when they try playing large videos on the realone player it gives a error or something like memory full?? why is that
is it coz of low ram?or is it somekind of bug on the phone....I converted a small video for the 7650 with real product and it worked perfectly fine??so will those vidoes work the same way on the 3650 ( i hope i dont get any memory full or anyother error message :-? )
i have to get a infrared port or bluetooth for the computer 😞 i coz i cannot send more then 1.5 mb through other phoes via bluetooth or infrared right??
how much does a MMC reader/writer cost :P?
