I tried to remove the front Xpress-on panel,but no success.The top side of the panel removes but the whole panel doesnt.Can you give instructions how to remove it!
How to remove the front panel
hi,
on the side in the high?! of the soft keys are one nose on each?! side. u must push in there softly to remove.
i hope that was the right way. i have only open it one time.
cya amigappc
Where to push?
You have to push all sides of the phone, first push down(near the charger), then the both sides<>, and finally press the hole up, its reverse.
bye.
Thanks i removed it. :P
