Problems Converting!
1 replies · 1,475 views · Started 16 June 2002
I am unable to pull across NIM files from my hard drive. Every time i drag the file to the My documents folder it just says copying for about 1 second and then exits the drag and drop program. All that i am left with is a file on the 9210 which when i try to open it says No instaled file! Can anybody help with this. Also the same happens when i try to upload some background pictures to it off 9210 wallpaper sites. Some convert and some dont. Please help!!!
I had the same sort of problem, copying just stopped after a while.
But if I left the bad file on the 9210 and then tried it again and overwriting the bad file it worked without any problems.
Good luck
