I have had a search for a spreadsheet editor for my p800, I just want to be able to create small spreadsheets of information, like on 3 colums by 8 rows that would fit perfectly on the p800 screen.
I cant seem to find any sort of spreadsheet software at all, just a viewer, is this right or am I not looking hard enough 😊
thanks for any help in advance!
Nope, not available yet.
I've used 'Docs to Go' on the Palm platform and it works a treat. Hopefully they'll port that to the P800.....
Yes not yet,but soon,i guess: www.symbiandiaries.com
There is a Java app called MicroCalc (or something like that)
Get it from www.wapindustrial.com
Haven't tried it but it might work (I think it worked on my 7650)
MicroCalc works perfect, just what the doctor ordered.
Everytime I close the app and try to re run it, it says cannot start MIDIet but other than that its awesome!.
Just wait a few sec longer before restarting the app and it will work fine
:angel: :angel:
[quote="scooter41"]... I just want to be able to create small spreadsheets of information, like on 3 colums by 8 rows ...[/quote]
So do I, but only because most of the ones I have to work with are so big that they won't fit on a 6-head display at 1600x1280 per screen.
I can't even watch Bloomberg TV whilst working on them!!
Fitting on one screen would be a novelty.
er, what can you actually do with anything that small?
(as the actress said to the bishop...) 😊
silly little things, like im organising a trip, and want to know whose paid deposit / full amounts etc.
I also do weight traning and want to store my progress on it,
well ok, i admit it, its a new phone and i want to use it all the time 😊
