Moving the applications in the 'Apps' folder
5 replies · 1,818 views · Started 01 May 2003
Any programmers out there could do this ? I think i speak for most of us when i say we would like an option to do this. It would be a really good idea i think, its pretty stupid you can't move emn.
Neway just thought i'd ask you guys
Not 100% sure yet...
The 'Applications' folder initialises the JVM to allow you to use the Java programs inside. I can't really see any easy way to do this in Symbian yet - but I would think there should at least be a way to add a shortcut to 'Applications' within 'Apps'
Haven't found it yet though...
There's a program for the 7210 that once installed in the PC Suite folder, allows you to install .jar files in a folder different from App. But that's for the 7210, it does not work for the 7650.
Being as most javas are games, Ive moved Apps into my games folder.
The only one I have that isnt a game is Webviewer
[quote="GaZ"]Being as most javas are games, Ive moved Apps into my games folder.
The only one I have that isnt a game is Webviewer[/quote]
hahah, exactly the same as mine!
