Windows 98??
18 replies · 3,631 views · Started 01 May 2003
I realise that this question must have been asked previously, but when i searched i could only find discussion centred around whether win 98 has USB conectivity and how people should change to XP or ME.
My laptop (well works laptop) has WIN 98 and they won't be changing it anytime soon, is there anyway i can get the software to make the P800 work with my computer or have i just bought an expensive phone with lots of gadgets i'll never be able to use??
p.s.
I'm not very computer literate so be kind!
I have win98 on my home PC and works laptop. I installed the PC suite from the Ericsson website, and there is a patch on there to, downloaded that and installed so the cable is picked up at the USB port and it all works fine.
convince work that 98 needs updating, they wont loose any vital data.
But where is the new upgrade!?
I can't find it on the SonyEricsson website :-?
Can anyone link it please 😊
Here you go. Was just downloading it myself
http://www.sonyericsson.com/spg.jsp?template=SP1_17&B=ie&FileCatID=4&start=0&PID=9940&LM=SD_V&MN=Synchronization&noredir=1
Hey there, Hi there, Ho there,
as my home PC still runs on Win98 (and a new PC is still far away - hey, I just bought the P800!) I had hoped with this new update I finally would be able to connect the P800 to my PC.
The installation of the PC Suite worked fine, but when I connected the docking station with the USB cable to the PC and Win98 asked for the drivers for this "new hardware" I pointed it to the folder into which I had unzipped the Win98-drivers downloaded from SonyEricsson ... but all I got was the error message that this folder doesn't contain any drivers! Now I wonder: what did I do wrong?? I did enter the DSS-20/98_ME/ as the folder so ... any ideas?
Thanks in advance for your help!
Yours sincerely
Dirk
[quote="stagestar"]when I connected the docking station with the USB cable to the PC and Win98 asked for the drivers for this "new hardware" I pointed it to the folder into which I had unzipped the Win98-drivers downloaded from SonyEricsson [/quote]
Surprisingly, you have to use the drivers that are on the CD that came with the phone. You can find the drivers on that CD in the folder that has drivers for ME_98 (sorry, can't remember the exact path at the moment). Those drivers will work - at least they did with me.
HI,
unfortunately the drivers from the PC-Suite CD do NOT work. If I point Win98 to the folder with the 98_ME-drivers for the DSS20 (the docking station supplied with the P800) I also get the error message that Win 98 did not find any drivers for the "new hardware" (the docking station) in that folder. 😞
So my question now: was anybody here successful with getting the drivers installed on a Win98 system?? :robot:
Yours
Dirk
[quote="stagestar"]was anybody here successful with getting the drivers installed on a Win98 system?? [/quote]
I was! And at least another guy here in Finland who I advised on a Finnish forum reported that by following my advice he also got the drivers installed on a W98 computer.
Have you tried first connecting the cradle, then starting the CD, choosing to install the drivers and then connecting the phone - after that you should follow the advice on the CD.
Hi all,
Whith this tread in mind i just tried it, and it worked!
What i did is this:
1. Uninstall any software relating to your P800 or //SE software.
2. Reboot
3. Plugin your desktopstand (DO NOT PUT THE P800 ON THE STAND!)
4. If alright, it wil ask for the drivers. Point it to X:\E:\Drivers\98_ME (Where "X" is your CD rom drive letter)
5. It wil instal the driversoftware.
6. Youl now get a message that Win98 has found new hardware aka (DCU-11) ans wil install the drivers.
7. Reboot
8. Download the last version of the PCsuite software from this link
9. Install it.
10. (just to be sure) reboot.
11. Put your P800 on the stand and it wil connect!
Good luck!
I still can't seem to get my computer to reconize the docking station. When i try and add new hardware it can't sem to find the driver. I've managed to get 1.4.2 pc suite loaded but the driver for the docking station still won't work
Any ideas???? :-?
I think it's something to with the fact that if you want the P800 to run on win98 you need DCOM98 1.3 installed. I click on the link and it seems to install but when i do the check they recommend
How to check if DCOM98 version 1.3 is installed:
1. Select Run... from the Start Menu.
2. Type regedit and press Enter to start the Registry Editor.
3. Find the following key in the Registry Editor:
HKEY_CLASSES_ROOT\CLSID\{bdc67890-4fc0-11d0-a805-00aa006d2ea4}\InstalledVersion\
I dont seem to have any bdc folders under HKEY_CLASSES_ROOT\CLSID
What does this mean??? Is there anything i can do???
This is very frustrating!!!!
[quote="Jem"]I dont seem to have any bdc folders under HKEY_CLASSES_ROOT\CLSID[/quote]
On my machine the letters are CAPITAL letters (BDC...), but I don't know if this makes any difference in your case?
Thanks Veikko
but my computer does't have the letters at all!
Is there Anybody else who can help???
try it as this:
1. Start "regedit"
2. Klick on the little "+" in front of the folder HKEY_CLASSES_ROOT
Now it takes a while but eventually a very long list of more folders should open up below the folder HKEY_CLASSES_ROOT set a few inches to the left, which means inside that folder.
The first part of the list consists of folders which start with a "." - but the one we are looking for starts without a dot!! So scroll down for ages, till you finally reach the entries without a dot at the beginning. Usually those staret with a large letter. They are sorted alphabetical ...
3. Now scroll down to the "C"s and somewhere there should be an entry "CLSID"
Note that this is not a "file" but once again only a folder!!
4. So click on the little "+" in front of the folder CLSID
Once again a long list consisting of even more folders is loaded and displayed below the folder CLSID set another few inches to the left, which means inside that folder.
They all start with a "{" and then a long number ending again with "}" - and this is the point: the first part of this seemingly endless list only has numbers at the beginning behind teh bracket!! So you have to scroll for ages, till you reach those entries with letters at the beginning behind the brackets - and yes, this is very, very far down the list!
5. So scroll the list down till you reach the "entry" / "folder" we are looking for "{bdc67890-4fc0-11d0-a805-00aa006d2ea4}" - note that most propably "bdc" will be written in capital letters - but it is the correct entry. On my Win98 system there are only two entries starting with "{BDC" so it is easy to overlook them, so scroll slowly and recheck once you are in the proximity of where they should be the sorted list displayed by regedit.
6. So click on the little "+" in front of the folder {BDC67890-4FC0-11D0-A805-00AA006D2EA4}
Now once again another folder should be displayed once more a few inches to the left below {BDC67890-4FC0-11D0-A805-00AA006D2EA4}. This folder should be called "InstalledVersion" if you click on this folder, a value will be displayed in the right window of regedit (so far we only worked in the left window). This is the value mentioned by SonyEricsson. It should be the value they mentioned or higher.
If you have downloaded the update from Microsoft and followed through the installation process as explained by Microsoft this should be as asked for by SonyEricsson.
Hope this solves your problem ...
Myself I still had no sucess getting Win98 to work with my P800, I downloaded the drivers for the DSS-20 from SonyEricsson (as these drivers are not included with the downloadable Sync-Software PC-Suite) but Win98 says teh folder into which I unpacked those drivers from SonyEricsson wouldn't contain any drivers for the docking station 😞
Yours sincerely
Dirk
[quote="stagestar"]Myself I still had no sucess getting Win98 to work with my P800, I downloaded the drivers for the DSS-20 from SonyEricsson (as these drivers are not included with the downloadable Sync-Software PC-Suite) but Win98 says teh folder into which I unpacked those drivers from SonyEricsson wouldn't contain any drivers for the docking station[/quote]
Yes, those drivers do not seem to work as you discovered. You will just have to find a CD that contains those drivers. My CD seems to be version 1.3.0, and it at least contains those drivers - hence, my P800 and Win 98 work together well. (That of course does not really anyone who has a problem...)
