Put midi onto Nokia 3650
12 replies · 2,312 views · Started 02 May 2003
Anyone can help me is there a way to put midi onto Nokia 3650
Can store mid in the MMC n act as ringtone for Nokia 3650
you can download midis and beam it to your phone using IR or Bluetooth... I think you can also use an MMC reader/writer to transfer files. And yes, you can use midis for your ringing tones.
you can also use the search button in this furom to upload the midi not only to ur phone but also up ur a**
Don't really understand. Pls explain further
How to beam? Using 3650 pc suites or .....
If I copy the midi files onto the MMC. How can I use it a ringtones
Just go to profiles and select the desired profile and then costumize it...
Select your midi from the list under ringtone or what ever it's named the first option.
don't know if its just me...but i uploaded ringtones once and they weren't available in my profile until i rebooted my fone (shut it off and turn it back on). either that or im just blind and didnt see it in the ringtone list when i was lookin for it the first few times
use Infrared or Bluetooth. if you don't have PC Suite and you just have a file on pc you want to beam, then just right click on it and if there's an IR device on your PC, you should get an option that says "send to nearby computer" or something. If you're using BT, then right click also and then there's a bluetooth option. Hard to explain. Have you installed any of these devices???
Hi st@rr, you are great but I still have difficulties putting midi onto Nokia 3650. I'm have 3650 pc suite (ver 1.0.0) & able to transfer pic between phone & pc & SIS installation using IR . Using PC suite, i can see everything in the phone memory but not the midi files
Hmm... sorry can't help with that 😊 I don't use PC Suite... I just beam my midi files directly to my phone and save it to the recorder. Maybe somebody can answer your question. 😉
Hi st@rr,
could you elaborate more (most appreciate) how you beam midi files directly to my phone and save it to the recorder? I'm using W2K, my ifra is enabled.
your help greatly appreciated
Alright, if you send via IR without PCSUITE, you get it as a message, whereas you open it, and save (you can't save it if your message settings are set to use MMC card instead of phone memory, cause it's already in the MMC! Why save it? :-?) in order to see them in the profile list, you have to put them in this file (i guess, well that's what i did after i couldn't see them anways) i made a file in system (or was it nokia?), and i made another file sounds and i put the midis there. So i can see them when selecting ringtone. You need a file manager for this.
As for using PC suite, they get beamed to your MMC right away. You can see them alright, cause everything on your MMC is visible when using PC suite. So make the necessary directory (if necessary, someone correct me if i'm wrong, i've been away from my 3650 for some time now! :cry😊 and viola! Hope it works 😃
I find the regular send to another computer a faster process, but when sending movies and large stuff, pc suite is good cause it's right away to the MMC
I use MMC for my messages and I can still save it to recorder 😊
Anyway, yeah... I beam it and receive the file as a message then I open the file and save it. It automatically saves in the recorder. Then you can see the file now at the profile's ringing tone 😊 that's it!
