MP3 Audio headset adapter
35 replies · 6,088 views · Started 02 May 2003
Just saw this:
http://www.pc-mobile.net/sp8aa.htm
But not available until May 9.
Pretty cool!!! But now I would like to see something where I can put in my own microphone as well!! Has some advantages for using it with your stereo or in your car.
Aha, just what I was looking for.
Now I've got my 128MB Duo (at last) I can use my P800 as an MP3 player but the earphones aren't much use at reproducing bass notes (obviously) and I have a nice pair of Sennheiser headphones that I would like to try with it.
Thanks for drawing my attention to it.
[quote="Brimme"]I just bought this adapter today. works like a charm[/quote]
how could u have bought it when its not out till may 9?
@Brimme: Where did you get the jack converter? I cant seem to find it in any of the electronice shops here. I was able to find a DYI one where you have to put the wire yourself but it only had 2 rings 😞 Is there a specific name for it?
it is very hard to find a good set of 2.5mm headphones with a microphone. I assume poeple are unhappy with the headphones supplied due to short lead between the earpiece?
My solution for those who has the money 😊
http://www.infosyncworld.com/news/n/3218.html
Ill definitely get this when it hits the market. Hope the headphones use a 3.5mm jack
cheers
Brimme, where did you get your adapter from? I'd like on too, but mainly for listening to music, not as an alternative to the earpiece/mic combo the P800 comes with.
I doubt I will get the MP3 player, but the headset adaptor looks promising, really.. Although a BT Stereo headset would be absolutely perfect! 😊
I just went to my local electronicsshop and talked to the mechanic there and ask if he had something but he said not in stock but i can look if i can order it and the next day i had it. so a normal electronicsshop that can order spare parts should be able to order it. it a 2.5 to 3.5 mm adapter
It is no problem to get a 3pole adapter from 2.5 mm to 3.5 mm, every electronic firm has that. The kick is to get a 4pole adapter with a microphone..
I will order one the 9 of may.
:halfrobot:
I cann't even get to their source CCNOW to order it...
I get the message:
Shoppers: Your browser program or your firewall security system may be set to "Disable Referrer Logging". If referrer logging is disabled, CCNow cannot track the source of your order.
I don't have enabled anyting like that.
:evil:
Thats helpful.. =.= I'm really wondering if its worth it, or not. I can't afford to waste my very limited money..
Order Number: XXXX
Order Status: Awaiting Shipment
Order History: 13 May 2003 - Received
Supplier: Pc-Mobile
http://pc-mobile.net
[email protected]
Im crossing my fingers, I hope I get them soon.. Ordered the adapter and the converter..
I use the adapter i got with my old mp3 nokia 55 something the crappy one with the wierd keyboard. that works fine and i can use my own headphones.
[quote="nickprice"]I use the adapter i got with my old mp3 nokia 55 something the crappy one with the wierd keyboard. that works fine and i can use my own headphones.[/quote]
Really? That old gameboy lookalike phone had it? I didnt look for that.. Oh well, I ordered it already so theres no use fussing about it 😊
Well, post some photos and tell us how it is when you got it ok? I wanna see if its good or not before I order.. 😊
I was a bit disappointed to discover the SonyEricsson BT in car kit won't carry MP3's off a P800 to a car stereo. On initial observation it looked like the ideal bridge.
Why didn't they build what looks to be a fairly simple additional feature in? Is BT too slow to carry good quality music?
Rohan
[quote="Accela"]Well, post some photos and tell us how it is when you got it ok? I wanna see if its good or not before I order.. 😊[/quote]
Sure 😊 Ill make sure to do that 😊
Finally it's here and it sounds good with my Koss headset! 😊 The packaging wasn't that good though... it came in a plastic rectangle case with a cover that won't permanently lock. The retractable baby plug adapter (for stereo) didn't even come in a case... it only came in a small plastic ziplock bag.
Hey, it works! All good for $15! 😊
Ugh. Your pictures are blur.. Never mind, is the design nice? Or looks bad? 😃 You sound like the quality is very good, so I supposed it is.
[quote="Accela"]Ugh. Your pictures are blur.. Never mind, is the design nice? Or looks bad? 😃 You sound like the quality is very good, so I supposed it is.[/quote]
Sorry bout the pics, not a lot of light in my room. Will try to post better pics soon 😊 The quality is so far very good.
