Trying to convert files with MM converter (Nokia) only the failuremessage appears: "an internal error oucoured during the file operation" , I have trying nearly everything, (but nat. not the correct) have try out both ver. 1.1 and ver 1.3 with same result. Also installed the prog. VirtualDub and first convered to .avi file as deschreibed with config. file as adv. but again same problems.
Problems with the MM-converter can anybody help me ???
NO
Installing the latest windowsmedia player seems to help, maybe it does for you 2.
Dazler wrote:Installing the latest windowsmedia player seems to help, maybe it does for you 2.
Hi I have installed the latest version of Media Player (ver. 9) and using Windows XP Pro. But also failed when trying to convert using this media converter.
Anyone can help ?
