steraming content...
2 replies · 1,023 views · Started 02 May 2003
anyone managed to stream a realplayer file online?
mine just says loading and then nothing happend?
vodaphone said the technology is not quite there yet and that they will be first tariff to launch in november?
Thats correct.
The networks are blocking the UDP packets needed to stream, Voda will be the first to lift the restriction in November when the put RealVideo content onto Vodafone Live - untill then they are keeping it blocked so they can control it and get the all the revenues when they launch it on their own site, like the greedy dogs they are :evil: 😃
Untill then - use Oplayer - it works TODAY and streams over GRPS networks..
www.oplayo.com
Best 😊
Will.
