Lock Code
3 replies · 2,112 views · Started 17 June 2002
Hi all,
I sent my communicator off to get upgraded to v.4.13(6) from 3.18 a few months ago. Since then I haven't been able to enter a successful lock code! I haven't really been all that bothered about it as I have been able to access the communicator functions, but now would like to secure the communicator.
Has anyone had this kind of problem, or can offer any suggestions about how to get it reset?
Cheers,
F.
HI,
i got the same problem, after upgrading the code was lost. I just called the Nokia center, they said that the code is re-setted to the factory default which should be 12345. That's right, enter those numbers and then you should be able to change it to whatever you want.
bye,
Ivan.
