Problems with the MM-converter can anybody help me ???
2 replies · 1,935 views · Started 02 May 2003
Trying to convert files with MM converter (Nokia) only the failuremessage appears: "an internal error oucoured during the file operation" , I have trying nearly everything, (but nat. not the correct) have try out both ver. 1.1 and ver 1.3 with same result. Also installed the prog. VirtualDub and first convered to .avi file as deschreibed with config. file as adv. but again same problems.
