realplayer prt2
2 replies · 1,678 views · Started 03 May 2003
in virtual dub do u use divx 5.0.5 codec? and in filters resize to 176x208?
and then change offset to +0+0 and size to 176x208?
still cant get full screen, video is smaller than normal size> 😞
[quote="guest"]in virtual dub do u use divx 5.0.5 codec? and in filters resize to 176x208?
still cant get full screen, video is smaller than normal size> 😞[/quote]
heh, where get you this?
you have bad settings. mr.Patcher dont say this!!!
read this thread http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=11236
you must change WindowSize and WindowOffset
he say not +0+0 !
you must change Offset to other params.
what r the param 4 the offset?
someone said the offset is 0+0+ ?
