Does anyone know the mapping of contacts......
3 replies · 2,027 views · Started 03 May 2003
from the 9210 to MS outlook?
I had created custom headings, but they don't appear in outlook, so I am re doing everything, so it appears in Outlook.
Appreciate your help.
N
[quote="barflux"]from the 9210 to MS outlook?
N[/quote]
Hi.
1) Outlook has limited contact card structure so if you have many numbers in the contacts card in N9210, not all items are synchronized.
2) Some items in N9210 can be seen in the Contacts window, but inspite of that fact, they are ignored by PC Sync. We call them "imperfect" records.
3) Custom headings will never appear in Outlook as Outlook doesn't support them and neither they are sent in the vCard from N9210.
See Contacts Manager's documentation for details (Outlook sync mapping table will be added into it very soon).
[quote="barflux"]Where can I find the contacts manager documentation? And what do you mean by soon?
N[/quote]
It is zipped with the application. You can find it in version 1.0 Beta on Handango or My-Symbian e-shops.
Soon means "after the Outlook-handling function is added to the Contacts Manager". We are working on it.
