Hello,
I'm looking for a pluggable keyboard for my 3650 to imput text easily. Do you know were I can find this kind of accessory?
Many thanks
Hello,
Many thanks
Where exactly are you going to plug it into? The 3650 has only Ir and Bt communication. No plugs...only for chargning of course!
the 3650 does have a data connection port, left up the sim card, although that would not be very sensible for a plug in keyboard
Ok A BT keyboard then ? :-9
:angel:
some keyboard for palm or PPC work on Ir with the right driver it should work for 3650
Who tell me the model ref. ?
Someone know where I can find a bluetooth or IR keyboard for the 3650??
I need one to write long Email :cry:
many thanks
Here's a few a pulled up in a search:
http://www.flexis.co.kr/web/intro.htm
http://www.brighthand.com/article/Dawn_of_Bluetooth_Keyboards
-DJ
There is no bluetooth keyboard yet,but if you've bothered to search the forum you would've known that drivers for the IR PocketTop keybord which works with some PockePC's are beeing developed so that the same keyboard would work with Series 60 and UIQ.
This might be off topic.. dunno. but here goes..
I use the program Remote S60 to use my PC keyboard to control the phone remotely and also write textmessages with.. (mail will be possible as well)
Of course. you need a PC nearby to use this 😉
If it was a help in some sort of way.. great.. if not? forget this post *lol*
With witch program you use for write sms and more with your pc keyboard? I've tried remote s60 but only numeric touch work, not alphabetic
[quote="ambretes"]With witch program you use for write sms and more with your pc keyboard? I've tried remote s60 but only numeric touch work, not alphabetic[/quote]
hmm. Wierd.. I write sms using Remote S60. Letters and numbers.. No difference.
