Editing Contacts on the PC ??
2 replies · 1,726 views · Started 03 May 2003
Just a quick question, is it possible to edit my contacts on the pc at all with any software, rather than editing them all on the phone?
Just wondered as most other phones support this feature
thanks for any help in advance!
Yes it is possible to edit your contacts entry in P800 with your PC. Edit your entry and sync again to down load changes you made on PC to P800. You can use MS Outlook, Lotus organizer....
If I downloaded the contacts to my PC it's gonna be as a file, how can I open this file in Outlook?
thanks.
