rm max file size
5 replies · 2,755 views · Started 03 May 2003
i made a realplayer file about 5mb and then put it on my phone but it only plays like 2 frames and then stopes playing but sound continues till the end?
this is what i did:
used virtualdub to compress avi to size ....
then i used rm converter to rm file
then upload>
short clips work fine but big files ?
where am i goin wrong?
[quote="peterpan"]this is what i did:
then upload>
where am i goin wrong?[/quote]
A good program for converting video and audio to .rm format is Helix Producer Plus 9:
Helix Producer Plus 9 (try KaZaA ;-p )
http://www.realnetworks.com/products/producer
You can download some jobfiles for Helix Producer here,
making encoding for mobile devices even easier:
http://www.realnetworks.com/resources/howto/mobile/index.html
(Tip: when RealOne Player sais the clip is too large, it doesn't mean the file size
but the video (screen) size is too large. I got it working with 176x144.)
i have a 30 mb mp4-file, and i can't see it when i use realplayer, but i allso have a mp4-file that is 4 mb, and it plays fine.
