Hey guys try this out, put an excel file on your P800 by sending it via bt or IR or just the usb-com thru the cradle.
You can then view this using viewer right?
Now, get the duo out, put it in the card reader(Forgot to mention, you need a card reader for this test) then connect the reader to your PC, open the same excel file. After doing this, put the duo back to your P800 and you will notice that the excel file has dissappeared!!
