Application Problem?
8 replies · 3,127 views · Started 04 May 2003
Hey guys... I have installed many applications on my phone and I noticed that my phone just turns off by itself and does not reboot! Now, I can't trace what application caused this problem... Here's the list of the apps I installed... Maybe somebody have installed some of my apps and encountered the same problem. Please help...
MGS Game Station
Video Camcorder
MP3Go
Bounce
Sync
irRemote
CardDeck
eProfiles
MVRPool
Handy Photosafe
Fexplorer
ScreenSaver
Task Manager
Torch
More than likely, it's irRemote.
Some phones reject the new PsiNT.dll file, causing the phone to reboot and not start properly (sometimes not at all).
Cheers
Ok, I'll try to uninstall the program and see if it'll work. Thanks!
anyway, the thread is still open for others' opinion 😊
No problem.
I suggest you remove the PsiNT library as well, but it may mean you have to reinstall some of the other PsiLoc products you have.
Hope it helps,
Cheers
😃 But not for long hopefully!!! (man this is getting annoying, i'm in a 3650 forum with a busted 3650. All because of IR REMOTE!!! :cry:
Suddenly it comes to Smiley's mind: not for long...
Muha- Muha- muHAHAHHAHAHAHAHAHA
I don't think it's the Task manager coz I installed it a long time ago before I installed those programs... It didn't cause any problem. Anyway, I've got no more choice but to install the apps one by one and see what happens! 😊 thanks!
