Gameboy colour
4 replies · 2,038 views · Started 04 May 2003
Hi all,
Sorry I had to start a new topic on this. I downloaded the gameboy colour emluator and some game roms and transfered them to my phone but I can't seem to start up any games, as I load the the game roms, the screen just goes back to the APPLICATION screen without loading anything. I wrote for help before but had no replys. Please help!!!
Many thanks!
I'm not sure how much use this will be but...
Mine doesn't do this and I think that the reason no-one replied the last time is that your problem is unusual. Have you tried the Lock Screen option on the menu first. It's possible that a hot key for another app is causing the problem.
If it's any consolation, GoBoy800 doesn't work as well as it might. The sound playback is a bit jumpy and without an external joy pad (or something similar) most games are very hard to control and the controls are not configurable (AFAIK).
slangley,
Thank you very much for your reply.
I tried the screen lock option, the result is still the same and I believe you about the game controls, I expected it to be hard as I experienced with SMS Plus games. I will just uninstall the whole thing from the phone.
Where did you download your copy of gameboy emulator as mine won't install. please help
