Installation Locations
3 replies · 2,313 views · Started 18 June 2002
Hi All,
I have formatted the memory card and the system of my 9210. I want to reload all the software back on so I have downloaded all_memory_card_data_v413 and all_nokia_9210_data_v413 from the nokia site. (I have 4.13 upgrade already)
Now do I need to install both of these installations? And If so which location? C or D?? I have 16mb MMC.
Many thanks
Stephen
To reinstall software after formatting the device
Install, all_nokia_9210_data_v413 first to C Drive. Then install, all_memory_card_data_v413 to the D drive.
(Just a reminder - you have to reinstall the same version to your machine v3.62 to v3.62 / v4.13 to a v4.13 machine.)
thanks mooky, much appreciated.
any other "must-have" apps you recommend... i only got this communicator yesterday and i just found this forum its great!!
thanks
Stephen
It depends what you want to do, but personally I use Power Data from www.epocware.com - it's great for making to do lists, making a simple database of notes, a journal / diary...endless uses User posted image and it's capable of exporting those nots, lists, data onto CSV, TXT, and HTML!
But there are some good things which come on the CD with the Communicator, like the Game Bounce, which is simple but fun User posted image
