can anyone leave step by step instructions for remote s60, i have read all previous posts about the program and still have no idea, ur help would be much appreciated
step by step instructions?
1. Just start you're connection with the phone like you do when you're using PC suite.
2. This time don't start PC suite but start the installed program on you're pc (RemoteS60.exe, or from the start menu)
3. Start now the S60 program on the phone.
4. Go back to the Remote S60 on the pc.
There you will see something like:
Clock on Start! to connect ...
Oke, press that Start!
5. Now you see the screen of you're phone.
If you now switch from task at the phone you can do everything you want remote.
That's all.
Has anyone got descent video framerate and quality on the PC? Just for information,i'm using the demo,but i dont think it has that kind of limitations.
[quote="GhostDog"]Has anyone got descent video framerate and quality on the PC? Just for information,i'm using the demo,but i dont think it has that kind of limitations.[/quote]
No, you can't get DECENT framerates for video, but quality is VERY ACCEPTABLE for what the purpose of Remote60 is, remote controling. 😊
I have the full version (I forgot to say that 😃)
i will try that once my pc begins to work again, i could use my moms laptop, but does the bluetooth and pc suite work with xp? all i am worrying about if i mess up the laptop. i never was able to get pc suite to work either but i will give it all a try now as long as everything will be safe?
Having problems with the .jar and .jad files.... do you install it like the .sis files ? Or is there a special installation method...
