Hi Guys, I have a P800 on Orange (PayGo) and cannot get my email to work 😞 Tried different ISP's and always get the same error : Error copying messages / (IPv6) No route available. EVERY time. this seems to suggest a problem with the v6 protocol but since I haven't heard of anyon else with this problem I'm assuming it's specific to my phone / setup.
Orange don't have a clue and neither do SE UK....hmmm 😞 Looking like it needs to be sent away which I didn't want to do...maybe a firmware upgrade would help ? Don't understand this....help appreciated. Thanks!
My P800 email problems :( Help appreciated!! thx
How are you connecting to the Internet on the phone? If you're using the 'normal' Orange GPRS Wap gateway, you'll need to find an alternate set of settings (from Orange) that give access to the Internet at large, not just WAP..
Can you browse the web with Opera with the settings you're using?
aaronjb is right - I had the same problem you're having when I buggered about with my GPRS accounts.
Use a GPRS internet account and it will work
Thanks for the comments guys. will try using GPRS and get back to you.
cheers.
