MSI Bluetooth version updated
13 replies · 3,644 views · Started 06 May 2003
does anyone have tried this newest version
Date: 2003-3-18
http://download.msi.com.tw/support/dvr_exe/bt49.exe
and having a problem with DCHP in winxp??? cause i tried to install it from a computer with a internet connection, after installing it, my dchp wont run anymore, i've lost network and internet connection and my dchp failed to get new ip address for my workstation
any possible solution about this???
currently i still use the old one
http://download.msi.com.tw/support/dvr_exe/bt45.exe
Sorry about your DHCP problem, I am using BT49 and have been for the last 2 months (since it was released), prior to this version I couldn't get anything to work.
I am also runing XP SP1 with PCSuite 1.2, mine works fine, I am connected to a corporate network using DHCP. Are you trying to use any BT networking on your phone?
Bob
[quote="mjsee"]but is it compatible with msi bluetooth transciever device???[/quote]
Yes it is,i'm using it right now.
[quote="Bob"]Sorry about your DHCP problem, I am using BT49 and have been for the last 2 months (since it was released), prior to this version I couldn't get anything to work.
Bob[/quote]
really??? i also running winxp sp1 with pc suite v1.2
did you do any special tweaking??? cause the error is the default gateway way is set to nothing ip address is different before it was installed then no more internet and network connection
BT networking??? how do it work??? i only do is to install some software and send / recieve images, is that what are you trying to point out??? or not???
but when i system restore my pc before i installed the new driver, then my system is back to normal
did you do tweaking or someting i did wrong???
[quote="GhostDog"][quote="mjsee"]but is it compatible with msi bluetooth transciever device???[/quote]
Yes it is,i'm using it right now.[/quote]
maybe if i didnt find any solution, i'll use it then... thank you for the link!!! and one question if you have msi bluetooth why didnt you use msi driver??? rather, you install billionton driver
First of all we dont install the Billinton driver...but the MSI driver! There is only one driver for your USB Dongle which is different for every device. However, the BT Software (or stack) is the same for both the MSI and the Billinton and many others. Billinton however has got the newest drivers available for some reason. The software on the link still installs the MSI driver, dont worry!
LOL, no. I use the software from Billinton that installs my MSI driver anyways! Regard it as one software for all devices. If you have a MSI, a MSI driver will be installed. If you have a Billinton, a Billinton driver will be installed. But I guess you ment software, so the answer is yes. I have the Billinton software installed and have no problems whatsoever! 😃
im a little bit confuse here 😃
oki... let just say i just formatted my pc, i just install billionton driver and software to my msi bluetooth transceiver??? can it be done by that without installing any msi driver/software??? or when it needed a msi bluetooth driver i just point out my driver for msi???
The software is from bilington,that is not really important,the important think is the stack which comes with the software,the stuck is bunch of drivers for bluetooth adapters,the same stack shuld be provided by all vendors,but like Muffy said,somehow,bilington has the newest.
In the bilington stack,the driver for your MSI adapter is included,so there is no need to install the MSI software first.
I hope that cleard some of it.
[quote="mjsee"]im a little bit confuse here 😃
oki... let just say i just formatted my pc, i just install billionton driver and software to my msi bluetooth transceiver??? can it be done by that without installing any msi driver/software??? or when it needed a msi bluetooth driver i just point out my driver for msi???[/quote]
No need to point out anthing. Everything is automatic. No need to install mSI Software first! Just install the Billinton!
