I am thinking about trying this, does anyone think it will work?
I am going to get a handsfree kit, one of the ones that has a little 2.5 mm plug that the headset plugs into into the little box that plugs into the phone
then get an adapter from radio shack so I can plug in headphones into it...
would it work, or would it only come out of one speaker and the other speaker is still a microphone...
Switchblade made a tutorial for this in the 9210 multimedia forum.
But basicly the best you get is the same sound out of the left and right speaker.
The 9210 only has mono ... the biggest flaw ...
you could create a program that uses the mono output to send 2 signals and then strip the 2 signals with some extra hardware into 2 headphones ...
but no chance in that happening :s
canu find that thread for me i dont know what to search for
