Well here's a new experience, I mean I experienced this before already but this time its worst. Everytime I install a game (I say games bec when I installed the demo it didnt happen) All the aps dissappear in the application section. All I do to solve it is restart my phone. But still, has anyone found the root of this problem?
Dissapearing Applications
have the same problem. I also just restart the phone and everything is ok again. Troublesome though
Very troublesome 😞
[quote="Muzikfreakah"]Well here's a new experience, I mean I experienced this before already but this time its worst. Everytime I install a game (I say games bec when I installed the demo it didnt happen) All the aps dissappear in the application section. All I do to solve it is restart my phone. But still, has anyone found the root of this problem?[/quote]
Do you really have to turn off the unit... coz when this happens to me, I just remove the M.S. then when the apps re-appears, I just slot in back the MS.... this way it's not so troublesome.
If you turn it off, you loose the folder settings of the applications - the correct solution is to remove and reinsert the MS.
I turn it off and so far Ive lost the folders once. I havent tried removing the MS will try it now 😊
Hey it works guys! Very good workaround 😊 Hope somebody can solve this though.. As for the moment, this solution will do 😊
Is it me, or did this only start to happen after installing a certain application?, did with me, everything was fine and it was auto updating the screen no problem...then one day this started and it's been like this ever since.
[quote="Jordan"]Is it me, or did this only start to happen after installing a certain application?, did with me, everything was fine and it was auto updating the screen no problem...then one day this started and it's been like this ever since.[/quote]
Same here. It happend to me once before and never again then lately, it just wont end anymore. Every ap I install results to this dissappearing phenomenon 😞 Atleast the push out/in of the MS is a quickfix 😊
