LAM-1 GPS - replacement/repair of antenna extension
3 replies · 2,144 views · Started 06 May 2003
My LAM-1 had an unfortunate accident when a bus swerved out in front of me recently. It landed on the corner where the antenna extension cable plugs into the LAM-1 module. Result - knackered connector on the end of the cable - it's pretty fragile.
Anybody any idea who might be able to repair/replace the end connector?
Alternatively, where to get a replacement extension unit from?
Have you tried your local Nokia Service Centre?? I had an accident with mine and they have replaced it straight away for me 😊 (mine was in waranty though)
-Wills
[quote="Anonymous"]Have you tried your local Nokia Service Centre?? I had an accident with mine and they have replaced it straight away for me 😊 (mine was in waranty though)
-Wills[/quote]
I haven't -only just happened, but I will - thanks. 😃
