P800 mappings for synchronization
5 replies · 1,510 views · Started 06 May 2003
Hello,
Is there a way to change the mappings of Ericsson's synchro program ?
When I synchronize with Outlook or Notes, the categories aren't synchronized (for contacts and jotter)
Thanks,
Patrick
I am not sure about the categories, but generally: the PC Suite software stinks :evil:
* It won't sync repeating items..
* sometimes I get duplicates (even though you are supposed to be able to fix that in the software). I think it has to do with items with HTML text etc in the body of the message.
* It won't sync subfolders to your contacts folder
* It is horribly slow
On my old Ericsson R520 the sync software rocked! I can't believe how bad this software is in comparison.
/Carl
I have just downloaded a "new" sync software from another webside will try it and keep u guys posted.
Hello WFTH,
Ok thanks.
But which software did you download ?
Thanks,
Patrick
old sync software from siemens s55, trying it 2morow, will update
If you guys have news about better sync softwares than outlook please post them
If you wanna read on how to migrate the Address Book from Palm to Outlook I posted instructions after getting it done yesterday.
Well if you wanna read my horror story of sync attempts with Outlook here's my full post: http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=12972
I posted full instructions on how I did achieve to migrate my contacts (address book) without using Outlook!
