Serius problem using MM-Converter
3 replies · 1,899 views · Started 06 May 2003
Trying to convert files with MM converter (Nokia) only the failuremessage appears: "an internal error oucoured during the file operation" , I have trying nearly everything, (but nat. not the correct) have try out both ver. 1.1 and ver 1.3 even with MM-Converter Pro same result. Also installed the prog. VirtualDub and first convered to .avi file as deschreibed with config. file as adv. but again same problems.
Really hope for som help!!! :cry: :cry:
I don't know what the problem is, but you can try a program called Cool Edit Pro. It can also convert audio and video files.
I use it.
I have same problem with MM converter.It seems to be problem with codecs because probably avi is hacked version of micro$soft mpeg 4.
I have no solution for this problem 😞(( if anyone know how to convert avi to nim lets post here plz.
