Change view to Landscape & Copy from MS Duo to another?
2 replies · 2,354 views · Started 07 May 2003
Can you flip the view from Portrait to Landscape view?
Also is it ok to copy everything from the 16MB MS Duo to a larger one, or do I need to re-install everything?
N
Dont know about the prtrait landscape view
With the memory stick just make a backup and reinstall with the new stick fitted everything worked OK on my change from 16mb to 128mb 😃
