Hi all thinking of getting p800 but i have a few questions
1. the lens of the phone is not covered, wont the lens get scracted or is special glass (like 3650)
2. can the keypad be taken off and pen be used to dial numbers (or use ur thumb to type)?
3. is it true that u can use the pen to write sms messages?
4. how does the weight and size compair to nokia 3650?
cheers i might think of a few more questions later
1. I believe the lens is covered by the same material as the touch-screen layer, and it's built a little into the unit so if you lay the phone down on a table the lens won't be touching the table(if you know what I mean :-? ). But of course you'd have to be careful about keeping the phone in the same pocket as your keys etc..
2. Yes the keypad can be removed. The P800 has a virtual phone keypad and a virtual QWERTY keyboard.
3. Yes, the P800 has handwriting recognition.
4. It's shorter, but wider and thicker. I guess the weight is about the same.
[quote="ceanth"]4. how does the weight and size compair to nokia 3650?
[/quote]
The weight of the P800 is 158 gram with flip on, 148 without
