I just found out the the recurring event on my outlook doesn't work on my p802. any suggestion
Recurring event from outlook doesn't work
You will probably find that it is only All Day Event, recuriign events that don't sync. This is because the calendar on the phone doesn't support recurring all daya events - madness if you ask me.
Only work around is to assign the event to a specific time!
It works with R2D update!!
r u sure, i hv the lastest version and it doesn't work
r2f
