how to take care of my 3650 camera
7 replies · 2,364 views · Started 08 May 2003
hi there
I just got my 3650 and the camera has got and im afraid about the camera wat if i scratch it or something
so can someone tell me how to take care of it :P
thanks
There's alot of ways to take care of it, avoid scratches by all means!
* Make sure you don't put your keys or objects that can scratch in the same pocket your 3650 is in
* Always put your phone face down on the table cause the front cover can easily be changed, but the lens can't!
* You can get an orignal Nokia pouch that has this way of protecting the lens. Or you can get a non-original 3650 cover the kind that has an extra part that covers the lens to protect it (somewhere from the far-east, search around (or wait a little while i find the thread 😃))
I put packing tape over the lense then cut around it. It is thick tape so scratches won't be a problem and the quality of pictures are the same, can't tell the difference.
Yep, get a leather case. I bought one on ebay and its great. Easily removable when I need to use it and you always know that you wont scratch the case !
