I was developing my first HelloWorld application in Symbian C++ .
I am building it through command line.
Steps followed:
1.Put *.MMP, bld.inf and *.mmf files in a directory.
2. Run "bldmake bldfiles" from command prompt.
3. Run "abld build" from CI
4. Now I get an exe file in a directory.
How do I run an exe file in an emulator??
Is there any other way of building this application.
Deepti
Just run the exe from windows. No need to start the emulator.
You need to specify that you want it built in the emulator directory, I think
abld build winscw udeb (if your using UIQ)
abld build wins udeb (if your using Series 60)
Then load up the emulator from the start😛rograms entry or from command line (C:\Nokia_Symbian\6.1\Series60\Epoc32\Release\winsb\UDEB\epoc.exe in my installation).
Your application should be in the 'Other' menu in the emulator
create workspace by "abld makefile vc6" and then build it using "abld build wins";if working in MS VC++ 6.0....
You can run the .exe from "C:\Symbian\OS7_7.0.9\bin\TechView\epoc32\release\wins\udeb\epoc.exe "
If the problem persists,write to me...
