The cards of the 3650 are the same used in 9210?
MMC cards of 3650 compability
I really don't know but i'd like to know too!
and... are there cards cheaper than de nokia ones?
Any standard MMC 128MB or less should work fine. Try Expansys, they had a 128MB MMC for pretty good price.
I'm not sure if it's the same as 9210... but if in the specs it says that 9210 has MMC then It should be the same with the 3650. All MMC's are the same. Anyway, I got my 128mb MMC for only $60... really cheap. Anyway, good luck!
Any MMC should work
can anyone give me an url where i can buy a mmc online?
or does anyone know where i can buy one in portugal??
tks in advance
9210 uses MMC, so the same would work. You can obtain online via www.expansys.com
I suggest you search around, you can find alot of places!! Including amazon and others.
I bought 2 (RiDATA & Crucial) MMC 128MB cards on Ebay.com at $40 & $41 each including delivery. I am in New York thought.
The MMC of 9210 are the same as on 3650.ALL MMC with capacity up to 128mb will work properly with firmware 2.50.FW 3.13 allows you to use 256mb MMC,without any bugs
I would not say that any 128MB or 256MB MMC card would work with Nokia 3650. Nokia is very relactant to improve their compatibility with products of other manufacturers. Their firmware would not be designed to be compatible with anything else. I can say that, based on many conversations I have had with Nokia reps and tech support in the U.S in the past few weeks.
Perhaps, Nokia in Europe has a more relaxed policy.
I've got a few 28MB MMC cards that worked in all my devices except my Nokia 3650 (the phone did not know that the card was there, so I couldn't format it). You should really test a specific MMC card. The best way to do it is in the electronics shop. Just test several cards, write down which were recognized by your phone and look for them on ebay.com to get a better price.
i agree with vic stone. i took a mmc card from a nokia mp3 player and it wasn't recognised in the 3650. also tried a 1GB card but couldn't format it. i believe that nokia must format the cards as they did with the 9210 cards. good luck 😃
had that same problem ... the 3650 seems to have problems formatting MMC's larger than (16MB?). try to format it first on a MMC Card Reader on your PC or have a mate do it for you. my bro's 32MB MMC on his ericsson t68i mp3 attachment had that problem. i formatted it with the card reader and it now works fine with his 3650
My 128MB MMC formatted fine first time in the phone.
Anyone try a 'simpletech' MMC? I found them real cheap online 128mb for only $50.00!!!
Think they will work in my 3650?
[quote="CoolMiKe"]can anyone give me an url where i can buy a mmc online?
tks in advance[/quote]
Fnac ou Staples Office Centre...no Stapples o 128 est� a 80�...
I've used a lot of SimpleTech CF cards and SmartMedia cards, but not MMC. Never had a problem with any of them.
