hi st@rr, i'm can send midi file now. Thanks for your help. To store midi files onto the MMC is not a problmes. But which directory/folder should I store in MMC so that I can to see them in PROFILE selection. How about WAV file
put ringtone in mmc
you must transfer sounds to the phone in order to be able to use them as ringtones.
if I will to use card reader, where (directories)should I place those midi files.
no, you can still use them as ringing tone if you store it in your MMC. Anyway, I placed mine in E:\sounds\digital... not sure of the path exactly. But that's about it. Glad to have helped 😊
by the way, if you're not using Fexplorer or applications like that... you cannot know the path. What I did before was, in my Sound Recorder, I went to Settings and changed the "memory in use" to my MMC. The tones will just be seen in your profiles even if it's stored in your MMC.
hi st@rr, by default midi files are store in C:\system\sound\digital\. I copy a midi files to E: (MMC) \system\sound\digital but i dont't see them the files that I copied from PROFILES.
I even went Sound Recorder & change the Settings to my MMC.
really? mine's working fine... I can see it in my profiles. I don't have my 3650 now coz I had it upgraded so I cannot check the path... But I'm sure it's in my E: drive and sounds folder. Good luck!
