I used my phone for 1 week and just now the 'Key lock' option disappearred when I press the option button with the flip on :-? . I have tried restart the phone and turning on and off the automatic keylock but none of them worked 😞 .
- Should I do a master reset?
- Is there any way to customerize the phone's option menu?
I think the key lock option "disappears" when your phone is charging. Once you disengage it from your charger, the key lock option will return
Yes, I just found it after a master reset. The keylock option would disable if you are charging your phone. If you lock it before the menu disappear, you will not be able to dial with the flip but you can dial with the flip open.
I love my P800 too even though its a bit bigger than modern phone. So far I have crashed once after installing several programs but it's pretty stable now. I think the firmware is much more stable than my previous T68 😃 .
Just a small tip EricC,you should not even compare the t68 with the p800.
The p800 runs on Symbian OS 7.0,i dont know what the t68 runs on,it is slow,buggy,its horrible,i dont think you can even call that thing an OS.
