New Remote! Control your P800 from your PC
41 replies · 7,314 views · Started 11 May 2003
Remote P800 - Operate your phone from your desktop PC With Remote P800 you can control your Sony Ericsson P800 from your desktop PC! Just use your PC keyboard and mouse to navigate on your phone.
http://my-symbian.com/uiq/applications/applications.php?fldAuto=248&faq=2
I think this is a must have ap since you can now text from your PC!! 😊
Im on trial version right now..
Man this is amazing!!! Very easy to install and use! And its realt time too, whatever you click on your PC clicks on the P800 right away! 😊
Woooohohohohohohoho 😊 Definitely one of the best aps ever made!
Now there are only two things lacking on my P800:
1.)Video Capture
2.) Office Documents reader/editor.
You guys should get this asap!!! This is something worth $15!! I guess I wont be getting that ap that could stretch pics at all.. its getting to be more expensive to me.. not worth 14 bucks..
[quote="Muzikfreakah"]Now there are only two things lacking on my P800:
1.)Video Capture
[/quote]
I have ASCII text editor, does it count? haha...
Dont have much use for that really 😊
O h yeah, and maybe a webcam application 😊 I think with this remote ap, a webcam ap for it wouldnt be that far away 😊
Cheers!
Im surprised why no1 has taken that much interest in this ap... Its is jsut superb!
I can now text through my PC when I have the P800 on the cradle. 😊
What is that white stripe on the left? (in the screenshot) I also have it... 😞
[quote="Cem Aygun"]What is that white stripe on the left? (in the screenshot) I also have it... 😞[/quote]
That's a restriction of the DEMO version only! The registered version of Remote P800 doesn't have any overlays of course 😉 ...
Cheers
Ole
Woohoo way cool app!
Though not to sure if it is this app or just my p800 being odd.
Since i have installed this my phone seams to stop charging for no reason and i need to take it off the cradle and putit back on.
Closed the remote link and no it seems to charge no pro again?
Is this just me or anyone else notice this?
OMG this app looks great, can't wait to test it tonight 😃
Can you connect to your phone over any instance? (Cradle, Infrared, Bluethooth, GPRS...????)
As you can record the movements made on the phone with it, does it record what is in the screenfinder of the cam app too?? :roll:
You can connect infra, bluetooth, and USB.
This program is awesome! 😊
Yip you can see what is in the view finder.
It uses the p800 mRouter.
So you can connect to your p800 anyway you use normaly for sync.
This ap is so good I think teh developers deserve a BIG CONGRATULATIONS!!!!! 8) 8) 8) 8) 8) 😃 😃 😃 😃
Im buying it as soon as I settle my bills tom 😊
Muzikafreakah asked about a Webcam,there is a program for PC(I cant remeber its name right now) that can stream your desktop real time to a webserver.So,using Remote p800 and that program,you can get some sort of a DIY webcam 😃
The program is called softcam.You can get it here: http://www.softcam.com/
At last. I had a program like this for my previous Jornada 928 which was a great help.
Tried the demo & quickly whipped out the plastic.
Got the full version by email with in 5 minutes of placing order with Handago.
No more having to remove the phone from the cradle to look up phone / contact details or typing messages, notes etc. 😃 😃 😃 😃
I case you'd not noticed, I'm Chuffed...
Legin.
[quote="KayonLord"]Woohoo way cool app!
Is this just me or anyone else notice this?[/quote]
I dont seem to be experiencing this problem.. Maybe your phone batt is full? But still the green light is suppose to stay on.. hmmm Try using another outlet or something
[quote="GhostDog"]The program is called softcam.You can get it here: http://www.softcam.com/[/quote]
I did stumble upon this program before but didnt know how to use it.. will experiment 😊 Thanks Ghost Dog!
Bat was almost dead.
But restarted the client software on the phone. And now it all works fine.
Yippy.
Though with this running and bluetooth head set charging is a very slow process.
Still love this app! This and tracker are deff my favs!
[quote="KayonLord"]Bat was almost dead.
Yippy.
Still love this app! This and tracker are deff my favs![/quote]
You mean you charge your phone and bluetooth headset at the same time? 😊 How do you do this?
No i mean with bluetooth turned on. And remote running, uses lots a batt.
Though all good!
Very happy puppy!
Mmm... wonder if smallbase is gonna come to p800.
Got lots a dbs on my 9210i.
Then i will be in 7th heaven!
Fantastic, I was hoping this would come out on the P800.. I've got the same (well, similar) app for my iPaq..
At last, writing SMS messages is no longer a PITA.. 😉
Problem is, handango or my-symbian wont let me buy it 😞
There is an update guys, version 1.10
They solved the problem with battery-draining as well!
I didnt really experience the battery draining but I did experience that sometimes you cant type on the screen.
Another problem I detected was when using JMSN messenger, when I type using the PC keyboard through Remote P800 when chatting with someone, I get double letters for every key I press eg: "hello" would appear "hheelloo"
[quote="KayonLord"]I still get the error with the ddoouubbllee letters![/quote]
Is this with JMSN also? 😊 I dont get this error with sms though 😊
Hi ...
Can anyone tell me if the Remote P800 would work in an Apple Mac OSX platform? Thanks!
