<b>SmartMemory is a highly useful tool, which displays the current memory usage of the Nokia 9210(i) Communicator directly on the desktop of the device!
<b>
How much memory do I have available? Unfortunately, this is a frequent question for all Nokia 9210(i) Communicator users, because the top-class device is indeed equipped with low memory capacity. Of course, the resources will decrease even more, if you install additional software or store many documents or files on the device. To avoid the complicated procedure of checking the control panel for the remaining memory capacity, you should better use <b>SmartMemory</b>!
<b>SmartMemory</b> permanently shows the current/remaining memory capacity of RAM, Drive C and Drive D of your Nokia 9210(i) Communicator, directly on the desktop!
<b>SmartMemory</b> provides a user-friendly interface, which includes well designed icons and the option to modify the size and colour of the text.
<b>Price US$ 2.95 !!!
Get more information here http//www.smartappz.deSmartAppz</a>
