Has anybody made MobileFax work ?
I installed the TRIAL version to test it, but when someone tries to send me a fax the phone does not answer the call.
Any answering machine for N3650 working right now ? As far as I remeber all versions had problems on 3650.
Thanks in advance,
Antonio
As answering machine you can use avista answering machine: you can find it here http://www.avista.ru/am.html
Regarding mobile fax are you sure it doesn't work? Tried both with regular fax and pc modem fax? I know mobile fax support fax class 2.
It should work with everything
Bye
I have a dutch 3650 and none of the available answering machines work , I tried them all, the caller doesn't get the response msg!!!!!!!!!!!!!!
WHy WHy WHy!!!!!!!!!!!!!!!
please someone help...
thx
[quote="hackazz"]I have a dutch 3650 and none of the available answering machines work , I tried them all, the caller doesn't get the response msg!!!!!!!!!!!!!!
thx[/quote]
Because of the changes made by Nokia to 3650 device media server firmwares 2.50 and higher it's not possible to play greeting message. It doesn't depend on the language version of the device, it's the matter of firmware only
There is some new app. called Mobile Assist, there is trial at handandgo.com, the real thing will be released late may... they say it works on 3650...
if not.... will this be fixed with some new firmware???
I have MobileFax and it works *VERY* fine !!!
PS: in order to answer of an incomming fax, MobileFax *MUST* run in background just like you have "Telephone" running always in backgroud.
Domi.
How Domi I don't understand it? Can you please explain in details 😞 Please help... Thx in advance :P :P :P
