play mp3
2 replies · 1,958 views · Started 11 May 2003
I understand that there is a MP3 player (Mp3Go)for Nokia 3650. Can anyone help me how can I play if i store the MP3 file in the MMC? Which directory should I placed (use card reader to transfer MP3 from PC). I can't access the MP3 fils.
You can access the files in your MMC... You can store you files in any folder in the MMC for example, E:\mp3... Just look for the folder. At first, you can only see the drives then just click right and it will expand... letting you see the folders inside E. Hope this will help!
I'll make my post clear. You see two tabs in mp3go right? The first is the player itself, the second is to look for your songs for the playlist. Go to the second tab and you can see the drives C,D,E right? Highlight E (if you placed your mp3s in the MMC) and click right to expand the folder. You should see the different folders you have on your MMC. Then just search for the song and select it. This is what I do...
