Enjoy..
excuse the url.. edit... moved clips to faster server 😊
http://194.164.20.8/terminator3.zip
http://194.164.20.8/thehulk.zip
http://194.164.20.8/matrixreloaded.zip
Edit... Some more..
http://194.164.20.8/animatrix.zip
http://194.164.20.8/toystory2.zip
http://194.164.20.8/toystory2b.zip
will 😊
Just downloaded 24 new movie trailers, abuse of the company network 😊
I'll convert & encode tonight, then do some more abuse of our network and upload them in the morning 😊
Payback for all the times you guys beta tested our adult movies & wap sites for �1.50 a go 😉
Best
Will
I'll be waiting for them!! 😉
how you convert files to rm and resize
thank you! :-? :-? :-? :-?
You need quicktimes quckeditor to turn the .mov's into .avi
Most other .mov to .avi converters will not work for movie trailers as the companies use a weird audio codec which other converters can not read..
Then feed the avi into RealProducer8 - or Helixencoder9 using real8 codec. You can also resize and crop widescreen into 4:3 (176x144) and produce the .rm file.
Do a search on these forums, it's been discussed many times.
If all you want to convert is .avi's and .mpeg's then all you need is the second stage. Most movies trailers are in quicktime .mov's thou.
Best 😮)
Will
Here you go...
http://194.164.20.8/chaliesangels.zip
http://194.164.20.8/chaliesangels2.zip
http://194.164.20.8/dusktilldawn.zip
http://194.164.20.8/entrapment.zip
http://194.164.20.8/et.zip
http://194.164.20.8/fightclub.zip
http://194.164.20.8/frequency.zip
http://194.164.20.8/interview-with-the-vampire.zip
http://194.164.20.8/jurassic-park.zip
http://194.164.20.8/men-in-black.zip
http://194.164.20.8/minorityreport.zip
http://194.164.20.8/missionimpossible2.zip
http://194.164.20.8/nightmareelmstreet.zip
http://194.164.20.8/scarymovie.zip
http://194.164.20.8/sixthsense.zip
http://194.164.20.8/sleepy_hollow.zip
http://194.164.20.8/terminator.zip
http://194.164.20.8/terminator2.zip
http://194.164.20.8/thematrix.zip
http://194.164.20.8/toy-story.zip
Enjoy 😊
Will.
thank�s for de trailers 😊
what�s the best format rm or 3gp???????
thanks
For downloading it has to be .rm
For streaming .mvq
For MMS .3gp
In my opinion..
One more:
http://194.164.20.8/matrixfinaltrailer.zip
Best
Will
ok i convert same file in rm and 3gp but the 3gp is better than rm (in my opinion).
i use nokia multimedia convert, easy and fast.
after I've downloaded the movie clips to my pc, how do i get it to my phone...and how do i watch it on my phone? I sent the file to my phone via bluetooth, but i don't know to to play it. Can anyone help? thanks in advance...
