There were a list of progs on http://www.theukserver.net/n3650faq ,but now the site doesnt open.I know that WILDSKINZ is incompatible with 3650,what another progs gave bugs to a 3650
INCOMPATIBLE PROGRAMMS WITH 3650
im not sure about this, PHOTOGRAPHER :roll:
Ok,Wildskinz,Photographer,what next.It is very neccesary Topic,when you will download a new prog,you will now,will it work on 3650 or not.And of course if it doesnt give SYStem error.
Photographer 2.0 or 2.2 works fine on 3650 as it's desigend to 7650 and 3650...
Yes,photographer works on the 3650,so first double check before posting.
[quote="The-Party-Boy"]im not sure about this, PHOTOGRAPHER :roll:[/quote]
I know why yours doesn't work 😉 hehehe! just kidding!
Anyway, I only know Wildskinz!!! I sent my 3650 back to my retailer coz it won't boot coz of that program!! So, please be careful!
[quote="GhostDog"]Yes,photographer works on the 3650,so first double check before posting.[/quote]
that's why im not sure about it. coz i install it on my fone and doesn't work.
Irvin,did you install the latest version,correct me if i'm wrong,but the latest version of photographer was designed/modified so it would work for the 3650.
not yet bro, i install the 2.0 it's system error. i'll try the 2.2 😊
I got the same problem with the Photographer 2.0... maybe the 2.2 will solve the problem!
wot exactly does this program photographer do?
Ok,now incompatible:wildskinz,photographer 2.0
[quote="fearce"]wot exactly does this program photographer do?[/quote]
www.openbit.com will tell you that...
I dont think that photographer 2.0 was ment to work on the 3650 so saying that photographer 2.0 is incompatible with the 3650 is exactly the same as saying that Remote p800 is incompatible with the 3650,or maybe not 😃
I think that the problem is simple. They are not thinked for the 3650 and lack support for MMC! But appart from that I think they should work fine if installed in C: and runned from there. Anyone has tried yet?
PS: I got a 7650 so I can't tell...
[quote="jimmy-floyd"]There were a list of progs on http://www.theukserver.net/n3650faq ,but now the site doesnt open.I know that WILDSKINZ is incompatible with 3650,what another progs gave bugs to a 3650[/quote]
The link is dead
Photographer 2.2 works with the 3650 8)
[quote="deathmonger"]I think that the problem is simple. They are not thinked for the 3650 and lack support for MMC! But appart from that I think they should work fine if installed in C: and runned from there. Anyone has tried yet?
PS: I got a 7650 so I can't tell...[/quote]
Will try this!
I know that a link is dead,thats why i posted a new topic.
[quote="ST@RR"][quote="deathmonger"]I think that the problem is simple. They are not thinked for the 3650 and lack support for MMC! But appart from that I think they should work fine if installed in C: and runned from there. Anyone has tried yet?
Will try this![/quote]
So you guys installed it on MMC? Photographer doesn't support MMC...
yeah! And I just knew now... I always wondered why I have problems in running Photographer. This may be the answer! Thanks guys!
Ok,we should install in MAIN(PHONE)memory.
Photographer will indeed run on the MMC. The trick is to first install it into phone memory and register it. After you have it successfully running on phone memory, uninstall it and re-install it to the MMC. Works like a charm on mine.
Peace,
Eidolon
Yup. Photografer 2.0 works on the 3650 if installed on c:
But now we have photografer 2.2 That is designed to be used with the MMC, who cares anymore 😉
[quote="Tatus"]Yup. Photografer 2.0 works on the 3650 if installed on c:
But now we have photografer 2.2 That is designed to be used with the MMC, who cares anymore 😉[/quote]
but mine won't 😞
you sure irvs? yours didn't work even if installed in c?
when im installing the program it's fine,but when i open the program it "system error" 😞
Incompatible programs can be progs for 7650,(old progs for 7650).So my advice is to download special progs designed for NOKIA 3650.
My advice is to check the developer website for compatibility,just a thought. 😮
yup and be very sure on the version of the app.
