9210 Will not switch on help?
9 replies · 2,222 views · Started 11 May 2003
Take out and replace battery, MMC, SIM card. Then put it on charge from the mains. It is worth trying this a few times if necessary with a short rest in between.
get the battery out, take a metal object and place this against all the pins.
This will get the last bit of energy out and will enable your phone to boot after inserting the battery.
At least it works for me 😉
Is the phone still in warranty? If so, I think it is time for a trip to your nearest Nokia service centre.
[quote="Dazler"]get the battery out, take a metal object and place this against all the pins.
At least it works for me 😉[/quote]
I didn't know that tip!!There's always to learn here!!! 😉 😃
[quote="bm8311"] After using Rolis 1.8 with my phone linked to my computer it switched off and will no longer switch on? Anyone any ideas what has happened it is dead? 😞
[email protected][/quote]
What exactly did you try and do with Rolis 1.8?? It might give a hint as to whats wrong (although I hate to say it but I think the phones messed up in a bad way)....
-Wills 😊
By the looks of it he has tried to unlock the phone or change the IMEI (roils will not work anyway on the 9210) anyway try putting the charger in the phone and then turning it on or try a diffrent battery.
