Navigation using GPS and citymaps
1 replies · 2,017 views · Started 12 May 2003
hi all
i've been trying out the GPS with tomtom citymaps but i have found one slight hitch.
i plan a route and have the GPS module enabled but when the road goes of the screen the GPS cursor follows off the screen but the map does not move to follow the cursor.
i have to physically press the down button and then the map changes and goes along the road to the next portion of the map i should be traveling along.
i dont know if this happens or am i doing something wrong.
all help will be appreciated
thanks
From the top of my head: go to Preferences | GPS and toggle the "Keep GPS position on screen" setting.
