Hi Chaps,
When I got my 7650 i installed the software suite that come with it but ive never been able to use it. I have a mitsumi bluetooth dongle and have installed the cd that came with that so that i can transfer files accross. I can transfer individual contacts via a business card but if i select the whole lot i can only send the data by email and not bluetooth.
The nokia software suite says it is unable to connect to my phone. Whats goign on?
Can't back up my contacts
Use the SERACH OPTION NEXT TIME!!!!! :x
You have to make sure you've mrouter connected to your phone. Is that little icon that seems like to connectors in your system tray, ok?
If you need more information, search the forum, you'll find what you need.
Sorry, i did search the forum b4 posting this topic. It didnt really help me understand why I cant get my pc suit to work. Ive tried double clicking the little icon in the system tray and have selected all of the bluetooth ones (about 7 of them I think) and still I can not get it to work. As for backing up the contacts.cdb file, i tried sending it via bluetooth to my machine using Fexplorer and it comes up file format unkown!
Im sorry, I have finally found the answer, does anyone have the Mrouterserial.dll file from pc suite 1.1 that they could email me please to [email protected]?
Kind Regards
Chris
