Hello peeps
I'm new here so be nice 😃 Been lurking for a while but I got a question for the knowledgeable kru (geeks :P )
I'm about to get a BT adapter but since i've heard about some problems with some models I need your advice.
I'm looking at the cheapest ones so that Belkin one which seems to work is a bit out of my price range.
Anyone had any experience with any of these or know any other in the same price range?
http://www.expansys.com/product.asp?code=USB-100
http://www.expansys.com/product.asp?code=ARM-USBBT
http://www.pecmobiledata.co.uk/acat...d_Bluetooth.htm (two from bottom)
Any info much appreciated
Cheers
xplizit
oh and any ideas of the range of the above devices?
Ta
I recommend billionton or MSI bluetooth adaptors. They work fine.
[quote="ST@RR"]I recommend billionton or MSI bluetooth adaptors. They work fine.[/quote]
links? prices? available in UK?
sorry... don't know the site. I just got them here at a computer store.
I've got a Conceptronic BLUETOOTH USB ADAPTER and so far has given me no problem at all, I'm pretty happy with it.
Take a look at:
@ ST@RR:
Is it the MSI 6967 u got? Is the range 100m? I've found it for �27 so it's all good. Seems pretty cheap even...
Try searchin on Ebay.co.uk, there's always bluetooth adaptors on there, some for around �20.
Just make sure you buy one that's compatible with your phone etc.
It's all good. I found the Belkin one at Amazon for �35. From what I've heard it's def compatible with the 7650. And it's 100m. Woohoo :bday:
You can get 13m tops with 7650,the Bluetooth chipset on the 7650 is lower class then regular PC adapters.
I use the tranciever key from MSI and it works great with the drivers from Bilington,and its cheapest 😃
MSI from ebuyer.com less than �30 including VAT and delivery, works with Win XP SP1, and PCSuite 1.2 as long as you download the latest drivers from the MSI website:
http://www.msi.com.tw/program/support/driver/dvr/spt_dvr_list.php?part=8&kind=23&CHIP=23&ID=8
16Mb download
Good luck
Bob
